Suspenssion
ive put a front strut brace on my 1991 ae92 seca, i can already notice the difference but was wondering if anyone had advice on what i should do/get when i upgrade from my factory shocks and springs, and also if thre is anywhere to maby find a rear stabiliser bar? thjanks
now many corolla owners use a similar setup which consist of KYB struts and king/lovell/or choice of springs.
by stabiliser? if you mean a rear swaybar you can't go past whiteline, as they have fixed and adjustable available for the ae9x series
and while your at it, i will also suggest checking and/or changing you suspension bushes as they are more than likely stuffed if the car is all original
