Cam Grind
Hi All,
when I bought my second 4k quite some time ago as well as the complete motor the guy I bought it off gave me a cam with iot that has already been ground.
now on the end of the cam the code " T121 " has been manually ground into it, does anyone know what grind this may be. the guy I bought it off was from west Auckland in NZ. I was just hoping maybe someone knew so I don't have to pay $100 to get it camdoctored just to find out what the grind is.
I need to know because I need to find out whether I will need to upgrade the bvalve springs or not.
The T121 is a Kent Cams Mild Road grind
270 Degrees duration
in timing 26/64
ex timing 69/21
in lift 9.74mm
ex lift 9.59mm
109 Degrees Lobe Separation Angle
0.30mm 0.36mm valve clearances.
It is very similar to the Tighe 113 and Tighe 104 that quite a few guys are running around here. Will give a very strong midrange with a wide powerband and a mild lope at idle.
you my friend are a legend.
