Smallport Intake Size
Hi I'm after the size (length form) from one side to the other not the diameter or depth, height or volume of the intake ports on a 100kW smallport 4AGE engine thanks.
Ian
I got 46mm long as apposed to my big port 60mm long if that’s the measurement you’re after.
Are all small ports the same?
I'm not sure if all small ports are the same but mine looks like a small port though it might be bored out as it is messuring 50mm from lip to lip then the inside is 46mm. Thank you for your help.
Ian
