June 18, 200917 yr comment_352990 Been doing alot a reading and aparently you can get a brake upgrade using the xt130 corona struts and stuff couldnt find too much on here to do this so i did some more research on other forums and found this :lol: xt130 brake upgrade n suspention hope it helps the people thinking of doing this and if u do have something like this on here my bad 8/ Report
June 20, 200917 yr comment_353472 I have just completed the following. XT130 Strut, Converted to Coilovers - As per article, work a treat. XT130 Hubs DBA Slotted XT130 Discs XT130 Twin Pot - Sumiatomo Calipers EBC Greenstuff Ceramic Pads All Cheap and easy, seems to initially be braking OK, but need to spend more time bleeding brake lines. Not quite right here, might need new master. Report
June 20, 200917 yr Author comment_353477 u need a bigger master for this brack upgrade otherwise ur paddle will feel spangy n go to the floor cause the 4 spot calipers need more fluid pushed in to them to get them to work and your orginal brake master dosn't push enough fluid to them this is y you have to pump the peddle. Report
June 20, 200917 yr comment_353539 You don't need a bigger MC for the conversion Mikey_M has done. The standard one is perfectly fine for the 2 spot Corona callipers. The H/P/C one in the link you posted is for massive 4 spot callipers from a Hi-lux. In the case of that, then yes you will need to upgrade to a 15/16" minimum MC. :wink: The other 4 piston upgrade that is more used is the RX7 calliper upgrade. Lighter setup with alloy callipers as opposed to big bloody cast hilux ones. Though, they both will make a 900kg corolla stop on a dime :y: Report
June 20, 200917 yr Author comment_353577 r fairenough i would still upgrade it thow to something bigger Report
June 21, 200917 yr comment_353886 Id be getting a New MC eitherway. I got TA22 brakes in a KE55, not huge but the pedal is spongey. But i got Pajero MC sitting in office ready to go in when i remember :bash: Report
