qikrla Posted June 30, 2009 Report Posted June 30, 2009 sorry might sound like a stupid question but I'm gonna ask in any way. just bought the rolla so don't no to much about it. just wanted to know if the indicators are supposed to flicker or just stay on? cause of the year model I'm not sure. mine just stay on if i indicate either way! I'm pretty sure there not supposed to! if so what do use think the problem is? its a ke30 75 model two door Quote
JiP Posted June 30, 2009 Report Posted June 30, 2009 All indicators should flash. You have a problem. You might want to check if any of the bulbs are LED's?? Cause if they are you need to swap the standard flasher unit for a LED flasher unit. Or maybe your flasher unit is cactus. Quote
