July 19, 200917 yr comment_359754 Thinking of putting a 20v into my 92 corolla. What are your thoughts? Are they a quick little car with the 20v engines? cheers Report
July 19, 200917 yr comment_359815 if its already got the 4age 16v its not worth the effort IMO, but if you have a 4afc/4afe its a decent upgrade :) but bear in mind that you will be putting an engine in with an unknown service history, when doing this conversion, don't skimp on parts, other wise you maybe doing another engine swap i the near future change or at the very least check the water pump (recommend changing it though) change the timing belt all ancillary belts cam/crank seals and a new clutch this is the very minimum i would personally do other than that good luck and have fun if you doing it yourself :P Report
July 21, 200917 yr comment_360364 I'm also considering a 20v into a AE92 with 4A-FE. Just not sure on what model front cut to ask for and what sort of wiring mods need to be done. Report
July 21, 200917 yr comment_360418 I'm also considering a 20v into a AE92 with 4A-FE. Just not sure on what model front cut to ask for and what sort of wiring mods need to be done. will depend on if you want a silvertop(ae101) or blacktop(ae111) wiring if you not so confident i suggest having it done professionally or by some that has done it previously, if you surf the forums or ask for help fairly sure someone will be able to give you pointers :P Report
July 21, 200917 yr comment_360419 whoops i wasnt looking and doubled up on the post :P Edited July 21, 200917 yr by MYSTIK Report
