i have put a 5k and 5 speed into a ke17 does anyone know what tail shaft combination i can use. i have the ke17 shaft which is the right length but wrong spline, i have a late ke30 shaft (aussie build) which is to long and the unis are not a match, anyone know which shaft i need (early jap ke30???) thanks for any info
Edited by curly
You will be able to pull the front yoke off your KE30 shaft and have it fitted to your sprinter shaft.
Cost me 75 bucks including replacing the front uni.
Mind you, I think the later 5 speed might have a different number of splines, so you may need one off a KE70.
