4K head to 3k block?
Yep but will lower the CR.
KE55 rear shoes and wheel cylinders same as ke70 wagon?
No idea, the answers are in the catalogs on the PBR and Bendix websites if you care to look for yourself.
cylinder head will bolt straight on but lower compression ratio somewhat.
there are two types of drums on the rear of a ke corolla, adm and jdm. jdm are bigger. I think that the wheel cylinders however are all the same. (ke30 onwards).
doesn't matter as to whether it is a jap or bw diff, brakes are interchangable.
Robert.
