hey I'm goin to build a 4k turbo i have a ihi vj11 turbo sitting here not sure if itll be small anuf. bought the stuff to relocate battery to boot today and probly picking the J-pipe up tomorrow. have to make the dump pipe probly use 3inch? can someone tell me where i get the oil feed from? and ima probly use a charade turbo fuel pump. and what would be a decent but cheap carby to use?? and if theres anything else thatll help me along the way info would be awsome.
cheers scott.
I don't quite know what happened to your other thread! :D
I did answer a couple of these questions in that.
Oil feed - Just T piece it out of the oil pressure switch. Click on "Tar" in my sig and there is a pick of this in the first post or 2.
Carby - I used to use a DTMR-A weber off a fiat 128, X19 would have the same carb though.
As for you fuel setup, I did a how to for carby turbo setups here...
http://www.rollaclub.com/board/?showtopic=17418
:D
