Hey Guys,
i am about to start a SR20 swap in my KE55 sedan, and have a few questions.
1 - Fuel rails? do they need changing...
2 - tail shaft.. does it need changing
3 - will the borg warner diff hold upto a SR20DET?
4 - engine angles.. what angle should it sit at?
5 - any advice / information or ANYTHING you have about putting an SR20 into a KE would be GREATLY appreciated.
Thanks heaps!!!
Hey Guys,
1 std fuel rails will do fine
2 no you,ll have to change it to suit your diff
3 see above. your going to have to do a brake upgrade anyway
4 the have to be in a perfect plane, you main shaft of your box has to be on the same plane as your diff pinion
5 work with an engineer whos going to sign it of, judgeing by Q4 get someone to help you because getting the motor and box mounted is by far the easiest job
