Hey
I have read the cam reamoval replacement thing. but I'm confussed on exactly what to do
remove rocker cover
remove rocker gear
remove pushrods
then this is were I'm confused this is were i remove the lifters how can i do this any ideas ? do they come out the top or the bottom do they have to come out ??
after this i understand the rest that aint a problem
cheers Bayden
they come out thru the top mate. sometimes they wear in a little which leaves a tiny lip at the top of the lifter bore. an extendable magnetic tool is sometimes useful.
The removal of the head will make getting the lifters out alot easier, if the heads not already off
Edited by SLO-030
its a probability you wont be able to remove the cam without removing the lifters. Once you slide the cam out enough for the lifters to drop off the lobes the cam wont wanna come out any further (or back in for that matter) as the lifter will be up against the next lobe.
