October 13, 200917 yr comment_381752 as topic states has anyone put an rsm in a ke70 still runing the 4k motor though or if anyone has the ecu pinouts cheers Report
October 13, 200917 yr comment_381791 ECU Pinouts? Not sure but I reckon there might be a couple of members that could help you out. I've not done this mod myself. Report
October 13, 200917 yr comment_381793 Good luck find the pin-outs for a ksev ECU!! :) You're most likely going to have to adapt a electronic speedo sender to give you some sort of speed pulse. These things (RSM's) are really not designed for cars that still use cable speedos. Report
