Ke70 Fuel Return Line
hey all.
I noticed today that the fuel return line on my ke70 was bucketing out fuel. I havnt got a hose attached to it as the new carbs i have don't have a return line.
Is there a way i can block it up?
Or should i maybe put a double fuel pipe on the second carb and run a hose back to the return line?
Any advice/help would be great
you don't have a return line? thats odd
umm try run a return line with a fuel pressure regulator
otherwise it will give too much pressure or burn the pump out
yeah no return line on the carbs. But i could make it go to the return.
And the pump i have has a regulator built in.
oh ok and the pump you have has 3 lines going to it?
1 from tank, 1 to carbs and 1 return? or just 2
just the 2. From the tank and to the carb.
It pumps until max pressure is reached then stops pumping.
wow high tech pump
in that case just block off the return line with a hose that has a bolt with the thread taken off hose clamped in one end.
goodluck with it all, hope to see you on the cruise
