November 12, 200917 yr comment_390698 Just been having problems with the A/C lately. After pressing either the A/C button or ECON button there's no sign of the A/C compressor turning on. No fluctuation in the rev's, can't hear the compressor. Does anyone know what the problem is? also, is there a downloadable Technical Manual? Cheers Edit. Just wanna clarify that its an AE100 Corolla. Edited November 12, 200917 yr by Kaz Report
November 12, 200917 yr Author comment_390713 Do you have all fan speeds? checked fuses? All the fan speeds work. I've checked this 30A fuse, and it seems to be fine. I'm not sure about the relays, i can't hear them clicking. As you can see the on/off light turns on with the button. is there anything else i can check? Report
November 12, 200917 yr comment_390719 With a test light or multimeter, see if you have 12v going to the clutch wire on your compressor when your a/c switch and fan are on.. Report
November 12, 200917 yr Author comment_390742 With a test light or multimeter, see if you have 12v going to the clutch wire on your compressor when your a/c switch and fan are on.. there's a 4 pin circular connector on the compressor, i tested the pins inside that and didn't get any voltage. however there are 2 other connectors coming off the compressor, one has a single wire and the other had two wires - i wasn't able to disconnect them to test. Report
November 12, 200917 yr comment_390752 It is usually the single wire that is the clutch coil wires, If the clutch coil is not getting powered it could be by a lack of a/c pressure in the system not causing one of the pressure switches to close its contacts and feed it.. Report
