Sprin/shockers Upgrade
Looking at upgrading my suspension in ke70, just checking what the go is.
If i'm looking to do it in stages, ie springs first the shocks, is that a bad idea......i can't really see why it wouldn't, but just wanting to clarify
Also if I'm upgrading to "low" springs, will the shocks i need to buy be different, such as short stroke, or does this apply for different purposes?
Thanks
Front:
AE86 Struts or XT130 Corona
6KG springs roughly
Short stroke might be a good idea, not 100%. Theres the cheapy for around $150 (KYB Excel G), AGX 4 way adjustables ($300?), TRD front inserts ($300?)
Longer LCA's if you want. XT130. Get new bushes and balljoints at the same time
Upgrade front swaybar if you want. I'm running a 24mm adjustable item
New castor rod bushes
RA40 tie rod ends if you do get longer LCA's. Some say you can run the stock one, but my mechanic didn't like it to much
Strut brace
Rear:
Short Stroke options: Boge turbo ($150?), Bilistien ($300?), TRD Blue 8 way adjustable ($200 - $300)
Springs around 4.5kg
Rebush trailing arms
First do springs and shocks together.
Second rebush
Third maybe swaybars
Last more track (LCA's) and Camber (LCA's and can even add in camber tops)
All just rough and quickly done, so if somethings wrong let me know :)
Also another thing to make sure is a good set of tyres can go a long way to.
Cheers Fusion
Edited by fusion
ahaha that list is almost identical to mine hey read sooo many builds :), might just wait until i have all the parts i need and install it all in one go instead of gradually.
Thanks for that dude, is this what you're running in your corolla?
Pretty much :) If you want me to take you out for a spin when I get the front springs sorted PM me :(
I personally didn't do it all in one go, so theres no reason you have to either. Financially I found it easier doing it over time as the above can add up to a couple of grand easily.
Cheers Fusion
