February 2, 201016 yr comment_410285 Hi, I have been looking through the knowledgebase/faq section and I thought I had found exacly what I needed, the KE70 chassis electrical system link, but it is broken and seems it has been for a while. I have just done the 4age into ke70 and it is running an EMS computer and wiring. the car starts and was run up on a dyno, I can't figure out the very last piece of wiring, the car starts by a switch but now I just need to wire it into the car, which will allow the ignition from the key and front and back lights to work etc. Does anyone have the pdf file missing from the faq they can email me or does anyone want to help me out finishing the wiring for some cash, i live in brisbane Thanks Edited February 2, 201016 yr by the_van_can Report
February 2, 201016 yr comment_410407 I have a Gregorys manual, but the useless sods only give a "lamp wiring diagram", so it has no ignition system on. I'm pretty unimpressed by it overall actually. If it will be any help I can scan it, but I think you will have to work it out wire by wire on the car. Report
February 2, 201016 yr Author comment_410425 I have a Gregorys manual, but the useless sods only give a "lamp wiring diagram", so it has no ignition system on. I'm pretty unimpressed by it overall actually. If it will be any help I can scan it, but I think you will have to work it out wire by wire on the car. I'm trying to imagine what "lamp wiring diagram" would include, if you don't mind scanning that would be helpful. I'll take a few pics of what I'm stuck on. thanks Report
February 2, 201016 yr Author comment_410458 ok so their is a plug on the top left of the engine bay which I get a reading from with the multimeter when i put the key to start. The following pictures is of the box that was located near the battery and plugged into a few things down there. So i'm assuming that box connects a few things together. Forgive me as I'm fully noob at wiring, the ems was wired by someone else. thanks http://i433.photobucket.com/albums/qq58/bl...ok/IMG_0484.jpg http://i433.photobucket.com/albums/qq58/bl...ok/IMG_0485.jpg Report
