Regency Defect - Bushings
Hi all. Taking my kesev through regency soon but i need to change the suspension bushes first. Just want to know if i can pass with Urethane or Nolathane bushes or do i have to maintain the original rubber ones from toyota?
Thanks.
Its just everyone is telling me any performance upgrade is another defect so would regency see the stiffer bushes on a ke70 corolla as a P plater making his car driftable?
no it will be fine just don't rock up on bump stops and a locked diff!
Urethane is a harder compound. Therefore it should take out a bit of slop in any moving joint
SO in theory, it should be looked upon as a safety enhancment.
Just like bigger brakes, they wouldnt look at you and defect you for them because you must need big brakes for the super high speeds you "COULD" do in school zones.
