I'm looking at a set of 15" x 7" superlites with a +24mm offset. PCD is 4 x 110 so there is no drama there. just wanting to know about the offset.
will these fit my ke20 before i go out and spend the cash?
any help muchly appreciated.
b.
i have 15x6 with an +20 offset on the front and the wheel sits pretty much flush with the guard, maybe just inside it.
15x6 with +33 offset on the rear sits inside the guard nicely, with a fair bit of clearance. No guard rolling was needed and still had a good gap between tyre and guard so with rolling the guards you could def go an inch wider. I have 7 inch wide rear wheels atm which fit perfectly with only rolling the guard lip, no flairing required. can't really help with offset on the rear as my diff is wider than stock and i have a big positive offset but 7 inch wide definitely fit inside the guards, will a slight guard pump a 8 inch will fit. Thats what ill be doing soon
Hope that helps
