April 24, 201016 yr comment_432298 ok so had a look at my ke11 from front on and both front wheels appear to be running positive camber, like a noticeably large amount. now is this standard ke1X or whats going on, does it have anything to do with the leaf at the front end? seems odd, never had this on any other corolla of mine. cheers nick Report
April 24, 201016 yr comment_432300 To much toe-in on the front wheels can make it look like that!! Get the wheel alignment checked, make sure you get the print out, then you'll know what's going on. Report
April 24, 201016 yr comment_432319 Pretty much standard for a ke1x. They were designed for crossply tyres not radials. Lower it an inch or so, add a front swaybar (keeps it flat and stops it leaning on the outer edge during cornering), rotate the tyres every 6 months and the tyres will wear evenly. Report
April 25, 201016 yr Author comment_432430 Pretty much standard for a ke1x. They were designed for crossply tyres not radials. Lower it an inch or so, add a front swaybar (keeps it flat and stops it leaning on the outer edge during cornering), rotate the tyres every 6 months and the tyres will wear evenly. yeh thats the plan, cheers for the response. nick Report
