May 17, 201016 yr comment_438130 hey guys this topic has probably been brought up before but i couldnt find it. I'm just wondering if ajps coilovers are an easy fit to a ke30 and if not whats a fair easy suspension upgrade? also I'm clueless about a easy brake upgrade. something that will pass engineering in victoria. Report
May 17, 201016 yr comment_438198 Yes A J P S can make you a set of coil overs to suit a KE30. Brake upgrade depends on how serious you want to get. Search around for the Corona/Puegot/Hilux upgrade. I think there's an RA60 upgrade aswell. Report
May 19, 201016 yr comment_438662 I wouldn't say its a huge upgrade but T-18 struts. On the brake rotors your going from a 218mm solid rotor up to a 230mm solid rotor, not much but the biggest thing about it is the shock absorbers, they run a bigger diameter tube which gives you a huge range of absorbers to pick from - commodore, corona, cressida, camira just to name a few... Report
