7k Engine In Ke70
in 7k which engine is best carburator or efi. allredy have 4k want to change to high speed engine.
use the search function, if you can't find what your looking for try fix up your spelling then retry
don't mind Evan, after receiving the same answer himself many times for his indiscretions, his only response is "use the search function"
If you can find a complete EFI 7K, including the computer and all the necessary sensors and looms, this would be your best option. It's likely to perform better and be a more reliable motor.
Whereabouts are you from Fawad, out of interest?
bro what is sensors and looms ? can u pls tell me thanks..
Philbey means all the electrics that go along with the 7K efi system.
Carby could be easier to set up initially, depending on carburettor choice,
but efi, as previously said, will most likely be a better long term choice.
Edited by KENut
