August 1, 201016 yr comment_456102 Hey fella's, I was planning on selling the boot with the hinges and stuff, although I hadn't actually realised they are spot welded on. Whats the best way to get them off? cheers Jesse Report
August 1, 201016 yr comment_456114 There is no best way to get them off. You can get a thing called a zip-cut which is basically a spot weld drill thingy. You want to be fairly good on the tools to use it, otherwise you'll do more harm than good. Report
August 7, 201016 yr Author comment_457455 There is no best way to get them off. You can get a thing called a zip-cut which is basically a spot weld drill thingy. You want to be fairly good on the tools to use it, otherwise you'll do more harm than good. Thanks redwarf. Thought I'd replied already. I'm thinking of giving it a shot. Do you know where I could buy one from? Cheers Jesse Report
August 7, 201016 yr comment_457471 Thanks redwarf. Thought I'd replied already. I'm thinking of giving it a shot. Do you know where I could buy one from? Cheers Jesse Any decent tool place should have them, Trade Tools, All tools, Glenfords, etc. Wouldnt expect Bunnings to have them, but you never know. Report
