Electronic Distributor
Mine have 2 vac port. What is the 2nd one for and how is it hooked up ?
there both vac advance, taz_rx said there used as a 2 stage advance
So can i just T the vac hose from the carby to both so they receive the same vac signal ?
correct! or use another random port on the carby like i did for my roady :P
Ive only got the one port, Ke11 carby.
Thanks mate :D
  • 4 weeks later...
The timing goes all over the shop with both vac ports used ? Stabilizes with only one used and advances like normal.
