August 17, 201016 yr comment_460187 Hey all, new to the forum bla bla bla anyway, A Ke70 corolla is on the books for me, but before i buy I'm working out the details of my future plans for the car yadayada. I'm planning on a W series gearbox to be mated to a 4a-gze motor. The motor in its final stage will be turbo and putting down some pretty ponies so i want a relatively tough and nice box to transmit it. After a fair bit of research i had decided on getting a custom bell-housing from 'niteparts', because although a bit pricey, the quality is apparently top notch and you can also fit a supercharged 4a flywheel in it will minimal modification. Then i came across a bright spark who stated that: "W55,7,8 all will bolt up to a T series engine using a G series bellhousing... Tailshaft in most cars which came with a T50 can be substituted with that of the automatic version, provided they used the A30 or A40." :D As you can understand this is music to my ears. But as i have no hands on knowledge with toyota gearboxes (only word of mouth) I would like a second opinion. Now my question is this: Can you bolt a W series (example, W58) gearbox to a 4a-gze motor using a G series bell-housing? Also, if i bought an auto Ke70 and decided to change it to manual early, would the G series bell housing also bolt up to the 4k? (I see no reason why not, seeing both the 4a and 4k bolt to the T series gearbox...) Report
August 17, 201016 yr comment_460190 Now my question is this: Can you bolt a W series (example, W58) gearbox to a 4a-gze motor using a G series bell-housing? Also, if i bought an auto Ke70 and decided to change it to manual early, would the G series bell housing also bolt up to the 4k? (I see no reason why not, seeing both the 4a and 4k bolt to the T series gearbox...) No... T50 come with different bellhousings to suit the engine they are behind. ie A series engine to T series box. T series engine to T series box. K engine to T series box. T series engines share the same pattern with G series. A series is on its own. and K series is on its own. Report
August 17, 201016 yr comment_460194 Found this ages ago, could be worth a look. A-W bellhousing Report
August 17, 201016 yr Author comment_460214 No... T50 come with different bellhousings to suit the engine they are behind. ie A series engine to T series box. T series engine to T series box. K engine to T series box. T series engines share the same pattern with G series. A series is on its own. and K series is on its own. Thankyou, but just a little clarification, wouldn't by that logic "A series engine to T series box" -> "T series engines share the same pattern with G series"? So does that mean a G series bell-housing doesn't have the pattern to bolt to the W box?? Found this ages ago, could be worth a look. A-W bellhousing Nice find. :D Edited August 17, 201016 yr by hotwyr Report
August 17, 201016 yr comment_460223 Thankyou, but just a little clarification, wouldn't by that logic "A series engine to T series box" -> "T series engines share the same pattern with G series"? So does that mean a G series bell-housing doesn't have the pattern to bolt to the W box?? People use the G series bellhousings to put W5x gearboxes behind T series engines. BUT. the A series engine has a different bellhousing pattern to both the T and G series engines. So the G series to W5x bellhousing can't be used. Report
August 18, 201016 yr Author comment_460431 People use the G series bellhousings to put W5x gearboxes behind T series engines. BUT. the A series engine has a different bellhousing pattern to both the T and G series engines. So the G series to W5x bellhousing can't be used. Isn't the 4a-c mounted to a T50 gearbox in the AE71 though? :D You are confusing between box and engine codes, most Toyota boxes run removable bellhousings so the gearbox can be fitted to multiple engines.The engine block pattern is very similar between T series engines and G series engines so they will interchange, so a G engine to W box bellhousing can be used to fit a W box to a T engine. Or a T engine to T box bellhousing could be used to fit a T box to a G engine. There is no engine that shares a common block pattern with the A series so you must use a specific bellhousing for the A engine, which for the W55/57/58 is aftermarket only. To confuse things a little further, the K50 gearbox has an integral bellhousing but comes in two different block patterns. One fits the K series block pattern, the other is for the A series block pattern and they can't be inter-changed. Which is a shame since you can get a K engine to W box bellhousing from some vans for you crazy K series build. Callum Okay, i think I'm starting to get it. ae71 uses an A>T bellhousing, making it compatible, BUT the G bellhousing, although using a rear W pattern doesn't have the bolt pattern to mate to an A block. So, custom it is. Didn't hurt to ask, but that's topic solved now. Thanks for the help. Report
