August 19, 201016 yr comment_460851 Hey guys I'm just wondering, if theres a way to remove or cover up the orginal back windows in a ke70/ae71 panelvan to make it look like they wernt there originally?.. any help is greatly appriciated. thanks. Report
August 20, 201016 yr comment_461029 find a windowless panelvan and cut the sections out cut your window sections out weld in ???? profit!! but yeah basically some came with windows some didnt, find one that didnt and cut the sections out. Report
August 23, 201016 yr comment_462067 guess it depends a bit on the style of windows you have there. my van has small, crappy homemade ones and what I'm going to do is buy some sheet metal, cut it to size and weld them in there. the full size windows like you see on the dx new zealand vans, well they would be a lot more work.you would prob want to cut the panels from a donor car in the case. Report
August 23, 201016 yr comment_462070 guess it depends a bit on the style of windows you have there. my van has small, crappy homemade ones and what I'm going to do is buy some sheet metal, cut it to size and weld them in there. the full size windows like you see on the dx new zealand vans, well they would be a lot more work.you would prob want to cut the panels from a donor car in the case. white goods sheet metal is what your after (dish washers/washing machines) load them up when its hard pick up :jamie: Report
