August 22, 201016 yr comment_461661 hey sorry to bug you all again, Just need to know a little more about my engine swap in my ke30 which has a ke55 engine in it but I'm going to a ke70 4k i got told yesterday that i need to swap my manifolds around and thermostat housing and what not do i have order in gaskets for a ke55 or ke70 4k??? hmmmm cheers paulie Report
August 23, 201016 yr comment_462073 inlet/exhaust manifold gasket should be the same for all K motors I'm sure. thermostat housing you can use some gasket goo on it, or worst case cut your own gasket out of gasket paper. most auto shops should have a gasket for your ke30 housing in stock. Report
August 23, 201016 yr comment_462106 inlet/exhaust manifold gasket should be the same for all K motors I'm sure. thermostat housing you can use some gasket goo on it, or worst case cut your own gasket out of gasket paper. most auto shops should have a gasket for your ke30 housing in stock. All those gaskets are the same I recently fitted a ke70 4k in a Ke50 which had a 3k. I used all 3k gaskets and they fit ok. Note, for the thermostat, it's the large part that bolts to the head. Report
