Hi guys
I successfully bush/desert rally a KE30 fitted with a 5K and a (KE70 I think) 5 speed box
It's been fantastic over the past couple of years, but the gearstick now feels as though (perhaps) it's mounting nut or whatever may have become loose or dislodged
If you keep a downward pressure on the stick as you change gears , everything works fine,........but if you don't keep the pressure down, or you lift the stick, it won't select any gears
I'm not a mechanic, I'm a little bit handy, but I know zip about gearboxes
Is this something I can reasonably easily fix myself, or do I take it to a mechanic?
I don't mind removing the box, but I don't have the experience to strip and refit the gears
Thanks for your help
Cheers pete
Sounds more like a shifter housing issue than anything with the gears themselves.
Try pulling out all of the rubber boots etc over the shifter so you can see the box. Have a look around the shifter housing and see if there's something not right. Could be as simple as the spring that holds in the shifter has wiggled past the circlip and loosened off some pressure.
+1 i reckon its the circlip. it popped out on my t50 once going through an intersection and i couldnt get any gears! haha. lift the covers and under the little rubber boot you should see the circlip. all you need is a 10mm socket to get the 1st cover off.
thanks guys, I'll give it a go
cheers pete
