Done and I like.
Cheap as compared to AE86 gear, larger stub axle for I guess more strength, large brakes and 2 spot calipers straight up (Also makes the P/H/C upgrade 1/3 done), large diameter strut tube allowing for decent range of shocks (as opposed to KE70 strut).
PROS: really good brakes (with CPH upgrade at least)
Sick cambers
CONS: Farking heavy unsrung weight
Steering arms are a slight hassle/niggle. Depends how picky you are
No backing plates
I don't think for the majority of people the large stub axle is too neccessary
Edited by KENut
1) Go to wreckers
2) Take complete struts, hubs and lower control arm from Corona
3) Unbolt *E7* gear
4) Replace with Corona gear
5) Get wheel alignment done
6) Enjoy
It is pretty much that simple, but you will just need to replace the corona strut top with the KE/AE one so it obviously canbolt into the strut tower. You may also have to just get some new brake lines made up as from what I remember, the corona 2 spot Sumitomo caliper uses a different fitting to the Girlock KE/AE calipers.
