Hi all,
Picked up a KE30 4dr a while ago and am in the process of creating a sleeper. Mid way thru body work etc but now attention has turned to the engine. Has anyone seen or heard of anyone putting a CA18DET in it. And would you be able to use the CA18DET gearbox? I realise alot would have to be custom as far as mounts driveline etc. Just throwing it out there. If anyone could point me in a dirrection it would be greatly appreciated.
Gergerov
You can put any engine in any car of course, depends how you want to go about it mate
if you want to do it yourself, the stock CA engine mounts and gearbox 'can' mount up to the body
otherwise Ford 250 Crossflow mounts and mild steel plates to align the engine where you need it to sit
otherwise get a shop to put it in, your location helps also
