Speedo Drive Cable To Suit
i just bought a ke35 coupe speedo for my ke55 coupe everything fits and works except the speedo out put is different
am i able to just switch the 55 speedo cable with a ke35 coupe so it will suit the speedo
Yes.
Oh wait...I read it wrong....You installed the cable, plugged it all in and the speedo is out by 5-10km/h?
The cable is the same, just a bit of flexible stuff that connects the sender gear to the speedo, what it sounds like you need to do is find a different toothed gear to put into your gearbox. I have the same problem so I can't tell you which is the correct gear (amount of teeth on the gear I mean).
Edited by jono1986
