Hi all, ive had a quick scan through the site and was wondering what rotor/caliper upgrades can be done, Ive got a 93 model seca (ae94) with the 4afe,automatic. The brakes are ok, but with heavy traffic they tend to fade. Have done the usual bleeding new fluid, changing pads, there isnt any leaks anywhere.
Thanks in advance for all your help.
Paul
Heya dude,running a search of the forums helps alot but to save you some time and effort this link should help you out. Its from the Toymods forums and has been a huge help in my AE101 Twin piston onto AE82 Twin Cam upgrade, hope it helps you too :-)
http://www.toymods.org.au/forums/showthread.php?t=142&highlight=ae82+brake+upgrade
This one may also be of some assistance...
http://www.twincam.info/index.php?showtopic=1063&st=0
Edited by carbonboy
Cheers, thanks for that.
Yeh, if i kept looking a bit longer, i came across the same thread about five minutes after i posted. In the middle of sourcing AE101 parts now.Looking forward to getting rid of the brake fade in heavy traffic and the hard pedal...
Thanks
Paul.
Get AE93 SX series 2 discs, if you can find the calipers use them but you can retain your original ones.
Then get some decent pads around the $150 dollar mark.
EDIT: If you do retain your original calipers you will have to sand the pad down a bit.
To do that you must find a rough & PERFECT flat surface sutch as a large paver, then
srub the pad down a tad by doing figurre 8's. You must apply even pressure to wear the pad evenly.
If you are not game to do this then forget it.
Edited by Twinky
Thanks Twinky..
shaving the pads is no dramas...
The Ae93 rotors, are they the 258mm dia,22mm thick ones? Is there a 2 pot caliper to suit? Sorry for the dumb questions,
Paul
Yes it is, DBA 708. Don't know of any 2 pots to suite tho. Don't need to go that far if it is just a daily driver.
I used EBC greenstuff pads with AE93 rotors on the race track with great results.
Kool,will hit the yards this weekend, ive got a warped passenger side rotor so gonna have to kick it in gear a bit.
Thanks for your help.
Paul
