November 24, 201015 yr comment_484101 Do ke70 wheel bearings fit onto ke20 sub axles? I've fitted the the whole ke70 lot onto the ke20 struts and there seems to be some movement when i fet the wheel... Edited November 24, 201015 yr by GJM85 Report
November 24, 201015 yr comment_484105 yeah you need to use a ke20 inner bearing far as i remember as it has the smaller ID but same OD as later Ke55/70... i think its in the faq if you want to double check - yeah confirmed Edited November 24, 201015 yr by styler Report
November 24, 201015 yr Author comment_484119 yeah you need to use a ke20 inner bearing far as i remember as it has the smaller ID but same OD as later Ke55/70... i think its in the faq if you want to double check - yeah confirmed thanks for the confirmation buddy! Report
