Log: Bens Engine Build
As of a few minutes ago my engine build is at this stage.
Pistons and conrods are out
Crank is out
Timing chain is off
Cam is still in the block
I'm currently considering sending the crank and rods off to get cryo freezed. I'm also looking into getting some standard bore ACL Duralite pistons. At the same time as the crank and rods are away I'll get the block hot tanked and decked so its nice, flat and CLEAN!.
EFI should be here in a week or two
