February 2, 201115 yr comment_500095 :bash: Hi Problem with my st141 cs toyota corona only when its a very hot day temperature gauge will rise half way. Car stalls, feel like starving for fuel cannot get acceleration ,when trying to restart ,until it cools down. Has anybody had the same problem Please explain help appreciated.. Report
February 2, 201115 yr comment_500107 Vapour lock. Your fuel is vapourising in the line as the pump attempts to "suck". Two fixes, first try running on Premium on really hot days, secondly install a small electric pump at the Tank end and you should be right. Report
February 2, 201115 yr Author comment_500137 [ Hi Thank you for the quick response. I run all my cars on premium. However, is this problem very common. Has anyone else experienced it. quote name=philbey' timestamp='1296615812' post='500107] Vapour lock. Your fuel is vapourising in the line as the pump attempts to "suck". Two fixes, first try running on Premium on really hot days, secondly install a small electric pump at the Tank end and you should be right. Report
