4Age 20Valve Into Ae93 Conversion Wiring Information
need info on the wiring for the 4age 20valve silvertop into ae93 engine conversion no one is ever specific about what to do with wiring
People can probably help if you have a go after looking over the 20V and 100kw diagrams. What are you stuck at? Half of it just plugs in if its and EFI car. Your car carby?
no mines efi and i havnt started conversion yet I'm just researching for when i do it in a month but i was just woundering what needs to be rewired, what will plug straight in and is it a problem that the ecu for the 20v will have an input and output for an abs module but the ae93 does not have abs?.......i know it isnt that hard to figure out once its in front of me but just wanted to see if i could get a heads up on exactly what I'm up against from someone who had done this conversion before
