Went into AutoPro the other day and ordered some bits and pieces to rebuild the front end.
-Lowered front Kingsprings
-Whiteline front swaybar
-new bushes for stock rear sway bar
-new wheel bearings all round
-front strut dust seals
The only shockers they had to fit were monroe, KYB apparently don't make any to fit. Has anyone else found anything else that works and might give me a slightly better ride without going to a Koni or anything like that?
Also is there anything else which would be worth doing while I'm at it?
Edited by rolleysou
  • 4 weeks later...
Bit of an update:
-Pulled the fron end appart
-rebuilt struts with low king springs
-painted all components
-replaced all bushes with nolathane gear
-mounted whiteline front sway bar
Finally convinced the rents to buy a welder :) and have tacked up the panel sut out of the rear right mud guard.
Still a long way to go b ut making progress
will post pics soon
