Bigport Pistons To 4Agze Crank
I have a bit of a technical question
how would i go using the early 18mm bigport 4age pistons
and using the 4agze rods
in a 4afe block
i have done some measurements
but just want to put the idea out there to see if there is anybody who would see some flaws or possible technical hurdles.
Harry
GZE rods are 20mm, you can't use early pistons on them, you will have to also measure the crank to see if it is a 40 or 42 bigend unless someone else knows.
thanks trev i will measure up and find out when i have time.
is the 4afe crank 40 or 42
That is what I am referring to, the GZE will be 42mm.
Did a search on the 4af and there is a post saying that they are 18mm but I would have thought they were 20/42 being a later engine.
Edit: Just found this via google:
http://www.rollaclub.com/board/topic/24959-4afe-engine-mods/page__view__findpost__p__287957
4afe = 18/40
Edited by Trev
