February 27, 201115 yr comment_506112 Hey guys need to replace the front timing cover seal on the crank of the 1980 rs132 corona. when removing the pulley the balancer behind does not have a center bolt??? All i can see is it has a key way and no thread in the centre. Does this mean i just use a puller to get it off? What holds the thing on the crankshaft?? Thanks guys hopefully someone has done this before. Report
February 27, 201115 yr comment_506238 Hey guys need to replace the front timing cover seal on the crank of the 1980 rs132 corona. when removing the pulley the balancer behind does not have a center bolt??? All i can see is it has a key way and no thread in the centre. Does this mean i just use a puller to get it off? What holds the thing on the crankshaft?? Thanks guys hopefully someone has done this before. I assume the pulley bolt "holds it in place", but I guess that means you need a puller. Get a gregory's! Report
