Ae71 Brake Upgrade
Hi all
Ok i need some help plz
I have a Ae71 with a sr20det that made 210hp on 8psi.
And I'm going to put a gt2871 on in the next couple of weeks.
And I'm getting it rdy to take on the track.
Ive got HSD coilovers on the way the front are Ae86 and the rear are mr2.
Ive got all swaybars and stratbraces.
I'm just wanting to know will 17"x9" fit all round.
And what brakes can i use.
It has the Ae86 brakes on it but i don't think they will last very long on the track.
You mite now the car.
let me know what i should do and will them wheels fit and how can i make them fit with out to much work.
Thank you for your time.
Is it hard to put on s15 hubs. Bcoz if I can put them on that will fix my brake upgrade.
You can go either 32/33 gts upgrade (non turbo) or s13 brakes and there the same pdc, only problem with s13 is there a single piston compared to 32/33 which are 4.
What's the diffrents with not turbo and turbo. And how hard are they to make them fit. Do I get s13 coilovers or r32 r33 ones.
You could go the s13 front end conversion which could if you wish give you power steering. Difference with 32 and 33 turbo to non turbo is turbo have 5 stud and the non turbo is a 4 stud.
Don't need power steering. Is there a thread on how to put it all in.
