April 8, 201115 yr comment_515745 Hey all, let's see if I get any answers for this one :hmm: Looking for pics on the exhaust mounting for an AE92 or even 82 corolla. Specifically looking for the mount at or just after the front crossmember, first mount after the flex connection. Mines broken and I'm not sure that it was the original mount regardless. I'm going to fab something up anyway, was mostly looking for inspiration. Report
April 9, 201115 yr comment_515979 On my AE82 I had a 'D' clamp setup, there was a U-shaped rod that looped around the pipe then the ends of the U were bolted through a flat bar that, before tightening, I had placed over a hook that attaches to the back of my engine block. Sorry about no pics, thought I did but FAIL. As long as you don't use a bit of builders strap & a tek screw like I have seen done, you should be good! Knocking up a cheap, easy fix shouldnt be too hard after some thought & a trip to Bunnings! :y: Report
