Will These Fit?
just wondering if these 16X7 +15 offset with FIRENZA ST08 205/45/16 tyres wil fit on a stock 75 ke30 without modification.
cheers.
The maximum backspace you casn have on most ke70s that run ae86 struts is 125mm.
They are 16 x 7 + 15 so the mounting surfaces meet 15mm outside the centre of the wheel. Being a 7J the wheel including the tyre sealing beads will be 8 inches wide. So 4 inches plus 15mm is your backspace. 115mm. Yes they will fit neat on a ke70 strut but you could go wider offset and or width if you wanted to make them look better. Look for an 8 inch at zero offset, or an 8.5 at neg 10 approx.
Edited by LittleRedSpirit
thanks for the help, i could get 16X8 on the rear with 0 offset and 16X7 on the front with +15 offset,
but do you think the 8 wides will fit into the rear gaurds without mod? i thought they might just be too wide
Edited by alex.wilson
anyone got any ideas on what 8's with a 0 offset on a stock ke30 rear suspension setup would be like?
