Ae92 Carburettor
I have the AE92 CS Seca with the 4AFC engine, I want to do a basic stock to street Carby conversion but I would like a turbo ready carby so i can run a low boost probs 4-6 lb. I don't want to do a 4AGE conversion at all i just wanted to change the Carby over. Which brings me to my question. What 2 Barrell carby could i use i don't want to spend a million dollars but i do want a fairly decent 1. I figure ill be spending around the $500-$600 mark. Has anyone done this yet? Webber/Holley with massive K&N Filter on top.
It wouldn't be an easy excercise and the gain would be hardly worth the effort. No one makes adapter plates for the manifold and there is a lot of pollution gear which you'd need to remove. The 4a-fc doesn't like it very much when you pull its pollution gear off.
The ideal twin barrel would be a 32/36 webber or a 180 holley. You'd need to have it rejetted.
What you should do is remove the head, have the cams done, extractors, big port work, get a custom intake manifold made to run a set of 40mm down draft webbers with 90 degree ram tubes sticking out of a wrx bonnet scoop. I think that may blow your budget though....
And then with half the money you could have bought a 4AGE! Seriously you could pick one up for less than a grand and have more power
than a 5 psi 4AFC.
Yeah alright I'll look into it
