August 20, 201115 yr comment_547987 hi guys i just bought a ke35 it has 4age stock engine i need u guys to help me out i want upgrade my suspension ,steering and brakes . i want to use this car for going to collage ( daily use) and i want to have a little fun aswell ( drifting donuts ect) plz help me out n i am planning to put second hand stuff for now cuz i am short of cash plzz help out people thnkz dj tabbzzz Report
August 21, 201115 yr comment_548005 I'd go ke20 lca's (20mm longer) for roughly 2 degrees of negative camber. Get some ae86 struts and brakes in with an otomoto weld on coilover kit. That way you have a bigger strut tube for more shock options and bigger brakes. Whiteline swaybar wouldn't be a bad idea either. Get the rear leafs reset instead of blocks. I will say this, you mentioned drifting, that will be pretty horrid with the steering box setup. Unless you're willing to spend a bit of $$ for a rack and pinion conversion i'd leave the corolla a daily and buy something better suited to drifting. Edited August 21, 201115 yr by Jono.C Report
August 21, 201115 yr Author comment_548209 hey thnks man ill look for parts but if i buy a halfcut ae86 what say its a good idea or not ? Report
