August 24, 201115 yr comment_548861 the cars a ke20 with a 4k 4 speed in it. the question i have is if i get a k50 box would it go straight in or would i need to shorten the tail shaft? will the gear stick hole line up??? thanks in advance Report
August 24, 201115 yr comment_548902 Tailshaft no. Shifter hole maybe depending on the car you get the 5 speed from. If its from a KE70 then you will be moving the shifter hole back. KE55 box should come out of the original hole. Report
August 25, 201115 yr comment_549260 Yes it is. As mentioned you wont need to shorten tailshaft, but there are a couple of different output shaft splines so you may need to change the front yoke over. Report
