September 8, 201115 yr comment_552372 hey guys putting my r31 turbo up for sale or swaps as i can't drive a turbo car anymore and need to get to work as i work out of town everyday. it is defected for 10mm to low at the rear and bald tires highcomp turbo conversion was carried out by myself with the help of a mate using highmount to4e with housing spun to sit low mount vlt injectors vlt ecu vlt crossover pipe 3 inch dump and front pipe into small sports system, nice and quiet doesnt attract any attention has all 4 14inch stock wheels will put good tyres on them for sale dash has just stopped ticking at 171xxx minispooled diff bad points: little bit of rust on the fuel filler and all the usual spots for a r31. is defected but depending on price or what you've got to swap it can be taken off defect and regoed again. making fairly good power for the minor mods that are done, stock just with the conversion it feels to be making 150rwkw plus running 9psi. cooler and full 3inch would probly see a moderate increase in power. would be a perfect base for a track car or beginner drifter, just wack a set of coilovers in and its done really. keen on swaps for a nice clean regoable ke70 or ae71. cash adjustments can be made if you have a 4age converted one :) but for price wise ill put $2750 ono. car is located in port pirie, about 2 hours north of adelaide. pm on here or msg 0487585042 anytime after 5 please :) sms for pictures and i can send them via email or txt Edited September 14, 201115 yr by dommobmx_16 Report
September 9, 201115 yr comment_552501 had one of these, almost same setup but mine was highmount with a front mount and exhaust, made 180kw on 7psi! very fun setup. Report
September 17, 201115 yr Author comment_554066 hey mate, whats your number ill send you some pictures? whats the ae71 like? Report
September 18, 201115 yr comment_554421 PM'd you my number ae71 is alright, body is in primer has s13 stockies and would need the gearbox replaced as it has no reverse. just orded chrome bumpers and tail lights from kay parts. I'll send you photos of it if you like Report
