stormchaser Posted September 9, 2011 Report Posted September 9, 2011 (edited) Firstly Id like to say hello my name is Jason and I'm new to the forum. Ok So now thats out of the way I can get to the point of my post. For a few years I have been following the progress of many Ke series drift car builds with the interest in doing my own. My local wrecker finally aquired a ok (read pretty bad) taxi yellow automatic KE70. After paying a small fee for the car including delivery I set out stripping the interior. I'm going to be updating this as a build so others can see what I have done and how I did it. I have a few requirements, they are listed as follows. Do it right but do it with budget in mind - I will be doing all the work myself. I will try not to spend money where I don't need to. I don't really know how to weld or panel beat or paint but I plan to learn how buy doing it on a car I'm not worried about wrecking. I'm doing this build with a friend and we are splitting all of the costs 50%. Build the car to adhere to cams/scrutineering rules- The car will be a track only car so I can cut costs and it wont need to be street legal. Here is the proposed parts list (if you notice anything wrong or could be better let me know) s13 SR20Det Red top Front cut (with front suspension/brakes if I can get a decent deal) Nistune of factory ecu or equivalent - This will only be needed when we want more power R33 or Z32 RB25Det Manual Gearbox and associated clutch to handle stock SR engine (for now) :) Manual conversion parts needed for change over replacement windscreen as the one in car has a hole in it- should I take this on or get it done R31 skyline diff with minispool Decent drivers seat and applicable harness Rollcage - either half or full Recommendations? Plexi/lexan windows as the drivers side ones are missing and I don't see any point in getting new ones as I would probably remove them anyway. Ba Falcon radiator and clutch fans- I have seen this installed into another car but not sure of ease of fitment. Cheap front mount intercooler- Recommendations? Will be adding pics very soon Thanks for reading. Jason Edited September 9, 2011 by stormchaser Quote
ke70dave Posted September 9, 2011 Report Posted September 9, 2011 id be having a good read of the CAMS manual before you start anything if you intend on making it cams approved. they have pretty strict rules, especially in the roll cage department. all the rest sounds good, though i see no mention of suspension? Quote
stormchaser Posted September 9, 2011 Author Report Posted September 9, 2011 id be having a good read of the CAMS manual before you start anything if you intend on making it cams approved. they have pretty strict rules, especially in the roll cage department. all the rest sounds good, though i see no mention of suspension? Hey thanks for the reply Definately will look into what needs to be done regarding cams. I'm not really sure what is the best way to go with the front suspension setup. Was thinking S13 cross member, lca's, coilovers, the rest I'm not so sure about. Suggestions? Quote
