diegoh Posted October 2, 2011 Report Posted October 2, 2011 I would like to have a 7k motor one day and just wondering which gearbox I could use to upgrade to a 5 speed when I go 7k or if anyone knows of a full mechanical 4 speed auto that could bolt up to the 7k? regards, D Quote
towe001 Posted October 3, 2011 Report Posted October 3, 2011 GM's 4L30-E basically its a four speed version of the trimatic (aka TH180/3L30) It has a split bellhousing like the trimatic but unlike the trimatic that was found behind a few four bangers it only, from what i could figure out, came behind sixes. BMW's 3 series, 5 series, Z3 Holden VR/S Isuzu/Holden Rodeo/Trooper I'm not driving my thing anymore so I dropped the ball on the idea You might be able to swap the bellhousings over between the 4L30 and trimatic. But the 4L30 was built for a six (or at least from what i could figure out) so you might find it a real slug behind a four. Quote
diegoh Posted October 3, 2011 Author Report Posted October 3, 2011 (edited) I actually thought toyota made their own 4 speed mechanical activated autos with aisin warner The liteace km20 or 1991 with 5k supposedly has a G40 transmission? Therefore I could use a g52 5 speed from a Hiace as far as I can find for auto I thought I could use the A43D??? or from the townace 85 model but don't know the code it had a 2y motor. reason I think the g40 is in atm & can fit g52 is due to this wiki text... The 1.8 L (1,781 cc) 7K was first introduced in 1983. Cylinder bore was 80.5 mm (3.17 in) and stroke was 87.5 mm (3.44 in). Was available with a 5 speed manual & 4 speed automatic transmission. 7K is available in KR42 Townace SBV vans (1997- 2007) using a large G52 5 speed gearbox (Same bellhousing to box pattern as W55), or automatic. Edited October 3, 2011 by diegoh Quote
diegoh Posted October 6, 2011 Author Report Posted October 6, 2011 can any gearbox guru confirm? Quote
