October 15, 201115 yr comment_560512 need to know if can buy some sort cage close to ke20 shape. ( even if i need to cut and shut 2 fit). or just build one? what be cheaper? Report
October 15, 201115 yr comment_560513 There are a multitude of cage builders about, and I'll tell you, if you don't know what you're doing, pay someone to do it. Bond roll bars in Sydney will do a kit and send it to you to install, otherwise, unless you live in the back blocks, there will be one nearby. I know of four in Brisbane alone. Report
October 15, 201115 yr Author comment_560517 There are a multitude of cage builders about, and I'll tell you, if you don't know what you're doing, pay someone to do it. Bond roll bars in Sydney will do a kit and send it to you to install, otherwise, unless you live in the back blocks, there will be one nearby. I know of four in Brisbane alone. what are the ones in brisbane. i live in warwick bout 2 hours away. do they build kits 2? do you no how many $$$$ Report
October 15, 201115 yr comment_560528 Most tend not to do kits. A cage will set you back anywhere between $1500 and $4000 installed depending on what you want. What do you want? 4 point? 6 Point? Tower to tower? Sainz bars? Roof bar? Side intrusions? Double cross side intrusions? Single/ Double cross in the main hoop? Single/ Double cross in the rear stays? Dash bar? As I said in another thread tonight, if you're not 100% on what you're doing, don't build it yourself. A bad cage is worse than having no cage. While we're at it, can you lose the SMS speak. We don't charge by the letter, and you're more likely to get an answer. This cage was done by a guy in Ipswich. Edited October 15, 201115 yr by Redwarf Report
