October 23, 201115 yr comment_562143 Hi all Stuart here Thomas dad , I was ratting parts of our donor car today and noticed it had a factory fitted double front transverse spring and was just wondering if this is standard on the ke10 as Thomas ke11 only had a single leaf or is it possible it may be a Bill Buckle special modification?????. I have removed it from the car, i will get Thomas to put pictures up when he gets home. Thanks Stuart. Report
October 23, 201115 yr comment_562173 I'm certain mine is a double leaf as well, might just be a model year change. Mine is a 69. Report
October 23, 201115 yr comment_562178 my 1970 ke11 is a double. could have removed one it in attempt to lower the car??? the Buckle cars had 1.5" lowering blocks in front and back from memory. Report
October 24, 201115 yr comment_562241 I don't quite understand how you can use a lowering block in the KE10 front end. The leaf is mounted inside the X-member. Report
October 24, 201115 yr comment_562265 I don't quite understand how you can use a lowering block in the KE10 front end. The leaf is mounted inside the X-member. I'm thinking the same. Mine is a double, 1970 ke11. Report
October 24, 201115 yr comment_562306 I'm thinking the same. Mine is a double, 1970 ke11. The block goes on top of the leaf pack inside the crossmember which flattens the leaf, hence lowering the front end Report
October 24, 201114 yr Author comment_562363 Hi there everyone thanks for all your replies i knew if i asked the question i would get the answer as i wasnt to sure although after pulling Thomas little ROLLA apart and putting back together so many times there is not to much i don't know about his car now anyway thanks again and by for now. Thanks Stuart. Report
