November 2, 201115 yr comment_564095 Hey rolla club, Just a quick question i had a person try and steal the ke55 and has destroyed the ignition Is there a way to remove the existing which has the centre pulled out. And how hard are they to replace and whats needed to change barrels. As i can't find anyone selling a bare steering column with ignition and keys to suit. Thanks, Joel Report
November 4, 201115 yr comment_564428 Hi Joel If you take the plastic covers you with see a small hole on the side of the casting facing the drivers seat about 3mm round. Now the tricky part, you will need to put a key in the barrel and turn the switch to ACC (first position), Push the little button down in the hole and you should be then able to slide/wiggle out the whole key barrel. I will post a picture if needed. Good luck Edited November 4, 201115 yr by Crostek Report
